השינויים המרכזיים
Added the "HDMI IN BYPASS" mode for Dolby Vision passthrough via HDMI In.
General fixes and disc compatibility improvements based on recent and upcoming UHD Blu-ray releases as well as user-submitted samples.
https://oppodigital.com/blu-ray-udp-203 ... BkedCTuF10
עדכון קושחה חדש לבעלי OPPO UDP-203/205
- bariko
- הודעות: 8000
- הצטרף: ספטמבר 2005
- נתן תודות: 1343 פעמים
- קיבל תודות: 329 פעמים
מישהו ניסה את זה?
http://oppo-jailbreak.store/
Frequently asked questions (FAQ)
www.OPPO-Jailbreak.store
Q: Does your jailbreak work with the latest original firmware version already installed on my player?
A: Yes, our jailbreak works with any firmware version already installed, including the latest version.
Q: How does the jailbreak work, do I need to open my player?
A: The jailbreak will be flashed using an USB-TTL serial interface connected to the Oppo mainboard,
so the player (casing) needs to be opened.
Q: Which USB-TTL serial interface do I need to buy and where?
A: We will provide an Amazon link to an interface which we know works 100%.
Q: Isn’t it dangerous to open my player?
A: It’s not dangerous at all, just don’t touch anything inside the player when it’s turned on.
Q: Do I lose guarantee/warranty when I open my player?
A: No, as long as you don’t damage anything inside.
Q: I’m not technically savvy and afraid to open my player, isn’t it very hard?
A: Honestly the jailbreak procedure is rather easy, but anyway, if you wish we can help you step-bystep on Skype.
Q: If there’s an official firmware update available, how long does it take for the jailbreak firmware to
be released and how can I get it?
A: Usually it takes 6-8 weeks after the release of the original/official firmware for the jailbreak
firmware to be released. As a previous customer you will receive any updated jailbreak firmware
from us for free as soon as available automatically delivered to your E-Mail address.
Q: Can I flash back the original firmware?
A: Unfortunately there is no way to go back to the official firmware anymore, as Oppo stopped to
provide the necessary old firmware files.
